RK05 Disk Drive
Disk drive with cover removed, left to right :-
- The disk pack with rear door open (for head access)
- The spindle drive motor is just visible below the disk pack
- Head voice coil positioner
- The black device in the foreground is the blower fan. This draws air
through the logic box to the right, and then expels is through an absolute
air filter (below) and then into the disk pack.
The power driver for the head positioner is at the rear right. The power supply
(not visible) is below.
Hints on Fault Finding on RK05 Disk Drives
The drive uses 4 x AA NiCd batteries for the emergency head retract. After 4
or 5 years the batteries generally fail, and if you forget to unload the drive
when you power down the system or the power fails, you will crash the heads.
If the heads crash and you get to the drive quickly, the heads will probably
survive after a good clean. The pack will be a total loss.
An easy check for the absolute air filter, is to open the bail door a place your
hand over the air plenum on the left hand side. If the flow is low, and you
don't have spare filters, use a vacuum cleaner to draw air in the reverse
direction through the filter and you should get much better air flow. Be very
careful with the plastic air duct between the absolute air filter and the
plenum chamber for the disk pack. The plastic is prone to oxidation and it may
fall to bits.
If the fault lamp comes on when you power up the drive, then the lamp in the
linear positioner has failed. They can easily be rebuilt using a 5 volt T1
sub-miniature lamp and 24 hour epoxy. Although I haven't tried it, a high
intensity LED should work just as well (don't forget a dropping resistor
to limit current to 20mA).
If you get lots of seek errors or seek incompletes, then the lamp is probably
on it's last legs (the envelope will be a silver colour). Check the Sine,
Cosine and Limit signal amplitudes and offsets. If they are a long way off
specification, then it is better to replace the lamp assembly, and redo the
calibration.
If the drive won't run up, check Bus AC and DC low. A common failure is the
wiring to the micro-switch on the front door going open circuit breaking the
interlock.
If you are having problems with bootstrapping, load a
trap catcher
and
manual bootstrap program
,and try to boot. After a few seconds,
halt the CPU and check the registers :-
Location Register Bits Description
777400 Drive Status 15-13 Drive ID
12 Drive Power Low
11 RK05
10 Drive Unsafe
9 Seek incomplete
8 Sector OK
7 Drive ready
6 Read/Write/Seek ready
5 Write protected
4 Heads in position
3-0 Sector Counter
777402 Error 15 Drive Error
14 Overrun
13 Write Lock Violation
12 Seek error
11 Programming error
10 Non-existent memory for DMA
9 Data Late
8 Timing Error
7 Non-existent disk
6 Non-existent cylinder
5 Non-existent sector
1 Checksum error
0 Write check error
777404 Control Status 15 Error
14 Hard error
13 Search complete
11 Inhibit bus address increment
10 Format disk pack
8 Stop on soft error
7 Controller ready
6 Interrupt on done
5-4 Extended memory address
3-1 Function
0 Controller reset
1 Write
2 Read
3 Write Check
4 Seek
5 Read check
6 Drive reset
7 Write lock
0 Go
777406 Word count 0177400 at beginning of bootstrap
0 at end
777410 Bus address 0 at beginning of bootstrap
01000 at end
777412 Disk address 15-13 Drive select
12-5 Cylinder address
4 Surface (head)
3-0 Sector
777414 Data Buffer
There a few companies that make RK05 disk controller compatible emulated
drives, try :-
Thruput Ltd or
ARRAID Data Storage Solutions
