The DEC 3000 AXP system family consists of both workstations and servers
that are based on Digital's Alpha AXP architecture.[1] The family includes
the desktop (DEC 3000 AXP Model 400) and desk-side and rack-mounted (DEC
3000 AXP Model 500) systems. The available operating systems are the DEC
OSF/1 AXP and the OpenVMS AXP systems. All systems use the DECchip 21064
microprocessor.[2]
The DEC 3000 AXP systems are designed to be significantly faster than
all previous Digital workstations and to offer performance competitive
with that of other reduced instruction set computer (RISC) workstations
currently available. In general, RISC systems have larger code sizes
and consequently require more instruction-stream bandwidth than complex
instruction set computer (CISC) systems. Further, 64-bit machines require
more data-stream bandwidth than 32-bit machines. To complement the power
of the DECchip 21064 microprocessor, the systems need a balanced system
architecture, including a high-bandwidth, low-latency memory system and an
efficient, high-performance I/O subsystem.
Traditional workstation designs that use a common system bus exhibit
increased memory latency and reduced memory bandwidth due to system bus
contention. This is a special concern for designs using a large number of
high-performance I/O devices. Increased latency can also result from the
additional levels of buffering and system bus loading common to traditional
architectures. Many system buses also exhibit multiplexing between address
and data, leading to further performance degradation.
To meet the goals of low memory latency, high memory bandwidth, and minimal
CPU-I/O memory contention in a cost-competitive manner, the designers
implemented the DEC 3000 AXP system architecture in an unusual way. They
chose to build the system interconnect from inexpensive application-
specific integrated circuits (ASICs), as shown in Figure 1. The ASICs act
as a crossbar between the CPU, memory, and I/O buses. Addresses and data
are switched independently by the crossbar.
The system block diagram in Figure 2 shows the system architecture of the
DEC 3000 AXP systems. The system crossbar in the center of the diagram
is composed of six ASICs, consisting of the ADDR ASIC, the TURBOchannel
(TC) ASIC, and four SLICE ASICs. The ADDR ASIC switches addresses between
the CPU, the memory, and the TC ASIC. The four SLICE ASICs switch data
between the CPU, the memory, and the TC ASIC. The TC ASIC switches I/O
addresses and data between the ADDR and SLICE ASICs and the TURBOchannel
bus. Connected to the TURBOchannel bus are the various I/O controllers,
including the dual small computer systems interface (SCSI) controller
ASIC, the general I/O controller ASIC, and the two-dimensional graphics
accelerator ASIC (not present in DEC 3000 AXP Model 400 systems). In
addition, six TURBOchannel option slots are available for expansion (three
slots in DEC 3000 AXP Model 400 systems).
DECchip 21064 microprocessor is the CPU of the DEC 3000 AXP systems.
On the Model 500, the CPU runs at 150 megahertz (MHz), and on the Model
400, it runs at 133 MHz. The processor is a superscalar, fully pipelined
implementation of the Alpha AXP architecture.[2] It contains two on-chip
8-kilobyte (KB) direct-mapped caches, one for use as an instruction cache,
the other as a data cache. Both the integer and floating-point units are
contained on-chip.
The block size of the B-cache is 32 bytes, matching the block size of the
primary caches. The cache block allocation policy used is to allocate on
both read miss and write miss. Hardware keeps the cache coherent on direct
memory access (DMA) transactions; DMA reads probe the cache and DMA writes
update the B-cache (and invalidate the primary data cache).
The DEC 3000 AXP systems are designed to be uniprocessor systems, which
simplifies the cache controller design in a number of ways. For example,
since no other CPU's cache can contain a copy of a cache block, there
is no need to implement cache coherency constructs such as a shared bit.
Further, by loading the B-cache during the power-up sequence and keeping
it coherent during DMA by using an always-update protocol, cache blocks in
the B-cache are always guaranteed to be valid. This method eliminates stale
data problems without needing to use a valid bit.
In addition to the cache memory, the subsystem consists of the cache
controller, the main memory controller, and the protocol control logic for
memory access arbitration.
The B-cache is alternately controlled by the CPU and the external cache
controller. When controlled by the CPU, the cache may be read by the CPU in
five CPU cycles. The cache data bus width is 16 bytes, therefore two reads
are necessary to fill a cache block. The Model 500 has a maximum cache read
bandwidth of 480 megabytes per second (MB/s). The cache may be written by
the CPU with an initial tag probe latency of five CPU cycles followed by
up to two write cycles of five CPU cycles each. The Model 500 has a cache
write bandwidth of 320 MB/s.
When a CPU probe misses in the B-cache, or when the CPU accesses the
external lock register, control of the cache is turned over to the external
cache controller. This logic controls filling the cache with the required
data from main memory, handing the data to the CPU during reads, merging
CPU write data into the cache on writes, and maintaining the contents
of the external cache tag and tag control store. In addition, this logic
maintains the architecturally defined lock flag and locked physical address
register, which can be used to implement software semaphores and other
constructs normally requiring atomic read-modify-write memory transactions.
The control logic for the B-cache consists of two interlocking state
machines. These state machines control arbitration and decoding of
processor and I/O subsystem requests. They also generate the control
signals needed to execute these requests to the CPU, B-cache, and main
memory.
The state machines prioritize and arbitrate requests from various sources,
including the CPU, the I/O subsystem, and the memory refresh logic.
Arbitration is done according to a fixed priority. First priority goes
to DMA requests from the I/O subsystem. Second priority goes to memory
refresh requests. Lowest in priority are requests made by the CPU. The one
exception to this scheme occurs at the conclusion of a DMA transaction.
In this case, the first arbitration cycle following the DMA changes the
priority to memory refresh first, CPU request second, and DMA last. This
guarantees that requests for CPU and memory refreshes are granted during
heavy DMA traffic.
The larger state machine, or main sequencer, examines the command
generated by the smaller state machine, or cycle decoder, and initiates
the control flow necessary to perform that command. Fifteen unique flows
are implemented by the main sequencer. They are
When a cache miss occurs and the new cache block replaces a cache block
that has been modified, as indicated by the "dirty" status bit, the
displaced data is referred to as a "victim block" or "victim data."
The many variants of cacheable reads and writes provide optimized flows
that maximize the parallelism of cache accesses and memory accesses. For
example, during the "read cacheable memory with victim block" flow, the
main sequencer reads the victim block from the B-cache and stores it in the
SLICE ASICs in parallel with reading the new block from main memory. The
same flow without a victim block makes use of the main memory access time
to update the tag store. The control flows for writes to cacheable memory
also take advantage of this parallelism. A further write optimization is
used when the cycle decoder determines that the entire cache block will be
written; in this case the data from memory is completely overwritten, and
therefore it is never fetched from memory.
DMA flows are entered upon request of the DMA controller in the I/O control
section. DMA control flows start by asserting a "hold request" to the CPU,
causing the CPU to cease B-cache operations within a specified time, after
which it asserts a "hold acknowledge" signal. It should be noted that the
CPU will continue to execute instructions internally until such time as it
experiences a miss in one of its internal caches, or it requires some other
external cycle.
Each DMA write to memory results in a probe of the B-cache for the DMA
target block, with a hit resulting in the B-cache block being updated in
parallel with main memory and the corresponding primary data cache block
being invalidated. DMA reads cause main memory to be read in parallel with
probes and reads of the B-cache. If a cache probe hits, the B-cache data
is used to fill the DMA read buffer in the SLICE ASICs; otherwise the main
memory data is used. In this manner, cache coherence is maintained.
A key design decision was determining the width of the memory data bus. A
conventional design would have matched the width of the memory bus to the
width of the cache bus (16 bytes). However, to reduce the memory latency
of the second half of the cache block (cache line size is 32 bytes), the
system reads the entire cache block from memory at once using a 32-byte
memory bus. This technique eliminates the additional latency from a second
page-mode read.
The DEC 3000 AXP Model 500 returns the entire block to the cache and CPU
with an average latency of only 180 nanoseconds (ns) from the CPU memory
request. In contrast, a less aggressive preliminary design using a system
bus and 16-byte-wide memory bus yielded an average memory latency of 320
ns. The 32-byte memory bus costs little more than a 16-byte bus-two low-
cost ASICs, resistor packs, and some address fan-out parts.
ADDR provides a home to the memory configuration registers. At power-on
time, the boot firmware writes and reads memory space, determines the
memory configuration, and writes the configuration registers. At run time,
each memory address maps into a unique bank, regardless of the type and
order of the single in-line memory modules (SIMMs) installed.
ADDR also provides a home for miscellaneous functions such as tag parity
checking, refresh counter, and the locked physical address register. It
generates the cache probe index to check the cache tags for a hit or a miss
on DMA probes.
As shown in Figure 5, an MMB module supports up to eight SIMMs at a time
(four SIMMs in Model 400 systems). A minimum of two SIMMs is required for
each board. A system always contains four MMBs. The MMBs act as a carrier
for the SIMMs and also contain drivers for address and control signals.
A total of 8, 16, 24, or 32 SIMMs (maximum of 16 in Model 400 systems) can
be plugged into the system. SIMMs may be single- or double-sided with 10
DRAMs per side. Each side of a SIMM constitutes one eighth of a bank. Eight
SIMMs must be plugged in to complete a bank; hence the 320-bit-wide data
bus (4 bits per DRAM by 10 DRAMs per SIMM by 8 SIMMs). One megabit (Mb),
4Mb, and 16Mb DRAMs are supported, and users are allowed to populate banks
in any order. In this way, the DEC 3000 AXP Model 500 can support from 8MB
to 1 gigabyte (GB) of memory, and the DEC 3000 AXP Model 400 can support
8MB to 512MB of memory.
Main memory is protected by a single-bit-correct, double-bit-detect error-
correcting code (ECC). In addition, the arrangement of data bits allows
the detection of any number of errors restricted to a single DRAM chip. ECC
corrections for CPU transactions are performed by the CPU, and corrections
for I/O transactions are done in the TC ASIC.
On DMA writes, 4 bytes of data arrive from the TURBOchannel interface ASIC
each cycle and are stored in the SLICE ASICs. The SLICE ASICs can buffer up
to 128 bytes of data prior to writing the data to main memory using page-
mode writes, 32 bytes at a time. To maintain cache/memory coherence, data
is also provided to the cache RAMs so that it may be written in the case of
a cache hit. On DMA reads, up to 128 bytes of data are read page mode out
of main memory and buffered in the SLICE ASICs. Data flows out to the TC
ASIC and the TURBOchannel bus at the rate of 4 bytes per cycle (100MB/s).
In the event of a cache hit, data is taken preferentially from the cache.
The crossbar employs a technique that permits simultaneous transactions
from CPU to main memory and DMA. The TURBOchannel bus supports DMA
transactions of up to 512 bytes in length. Once the DMA starts, the system
must be able to provide or receive data without any gaps. However, while
the DMA buffer in the SLICE ASICs is sufficiently full (for DMA reads)
or empty (for DMA writes), the CPU is allowed to use memory. When the I/O
controller detects that the buffer is too full or too empty, it requests
memory time to service the DMA buffer. At this time, further CPU requests
are temporarily ignored. This technique prevents the CPU from being locked
out of main memory, even during long DMA transactions and even though DMA
has priority over CPU transactions.
The crossbar also permits simultaneous write transactions from the CPU to
main memory and from the CPU to an I/O device. SLICE and ADDR ASICs can
buffer one I/O write transaction of up to 32 bytes in size. Once the ASICs
have accepted the data and address, the cache and crossbar are free to
process other CPU transactions, which can include cache and main memory
reads and writes. If the CPU issues an I/O write while a previous write is
still pending in the ASICs, the cache controller simply stalls.
The system interfaces to the TURBOchannel bus by a data-path TC ASIC and
control logic contained in a number of programmable array logic devices
(PALs). The TC ASIC completes the system crossbar by passing addresses
between the TURBOchannel bus and the address ASIC, and passing data
between the TURBOchannel bus and the SLICE ASICs. Furthermore, the TC ASIC
checks and generates parity on the TURBOchannel, and checks, corrects,
and generates ECC on the data bus to the SLICE ASICs. Parity checking of
TURBOchannel data is optional and is enabled on a per-option basis through
a configuration register in the TC ASIC. Finally, the TC ASIC contains
a number of counters for tracking DMA progress, as well as configuration
and error registers. All control logic was implemented in PALs to minimize
the impact to the project schedule of any design changes. The TURBOchannel
interface block diagram in shown in Figure 6.
There are two types of TURBOchannel operations: the system initiates I/O
reads and writes, and the options initiate DMA reads and writes. On an I/O
operation, the system sends the I/O address from the ADDR ASIC to the TC
ASIC, and from there to the TURBOchannel. For I/O reads, the option returns
data on the TURBOchannel. This data passes through the TC ASIC and over
the bus to the SLICE ASICs. The system includes some special hardware for
byte masking of I/O read data. This hardware is used to provide support for
VMEbus adapters.
For I/O writes, the system sends data from the SLICE ASICs across the
data bus to the TC ASIC. The TC ASIC then sends it to the option over the
TURBOchannel. The DEC 3000 AXP workstation supports a block write extension
to the original TURBOchannel protocol. In this mode, the system supplies a
single address followed by multiple consecutive data transfers for improved
I/O write performance. This extension is also configurable on a per-option
basis through the TC configuration register.
The TURBOchannel protocol specifies that before any option can use the
bus for DMA, it must issue a request to the system. The DEC 3000 AXP
architecture employs an arbitration scheme using rotating priority that
prevents any option from being locked out. After being granted the bus, the
option supplies a DMA address on the TURBOchannel bus. This address routes
through the TC ASIC and onto the address ASIC. In the case of a DMA write,
data immediately follows the address on the TURBOchannel. This data passes
through the TC ASIC and onto the data bus to the SLICE buffers.
DMA reads are more complicated than writes because the TURBOchannel bus
does not transmit ahead of time the number of bytes of data to be read from
memory. Instead, it continues to assert its read request signal for as long
as it is requesting data. The SLICE buffers begin to fill up with DMA data,
and only when they can guarantee that there will be no gaps in the DMA will
the data transfer start. The TC ASIC receives the read data from the SLICE
ASICs and sends it onto the TURBOchannel to the requesting option.
Virtual DMA allows the system to map noncontiguous regions of physical
address space into contiguous regions of virtual address space. This method
allows TURBOchannel options to transfer large blocks of DMA data without
knowledge of how that data is mapped in the physical address space in
main memory. Virtual DMA enhances operating system performance because
the memory mapping is performed before the transfer of DMA data.
The DEC 3000 AXP workstation supports virtual DMA through the use of a
scatter/gather (SG) map, which acts as a translation buffer. SG mapping is
enabled on a per-option basis through the configuration register in the TC
ASIC. The SG map is organized as 32K 24-bit entries. Each entry contains a
17-bit physical page number (PPN), parity, and valid bit. Software sets up
the map through I/O space reads and writes. DMA byte address bits [27:13]
index the SG map, which produces a 17-bit PPN (bits [29:13]) to append to
the virtual DMA byte address bits [12:0]. The resulting 30-bit physical DMA
byte address can then address all 1GB of the possible system address space.
An S/G map is shown in Figure 7.
The IOCTL ASIC provides an interface to a 16-bit, general-purpose I/O
bus, which supports the following devices: two Zilog Z85C30 serial
communications controllers (SCCs), an AMD 7990 local area network
controller for Ethernet (LANCE), a Dallas semiconductor DS1287 real-time
clock, an AMD 79C30A ISDN data controller (IDC), a SCSI controller, and an
AMD 27C020 256KB erasable programmable read-only memory (EPROM).
The SCCs implement the keyboard, mouse, alternate console/printer, and
communications ports. The mouse and keyboard do not use DMA. The alternate
console/printer and the communications port do use DMA.
The LANCE implements the Ethernet interface, which connects to the local
area network (LAN) through either the AUI (thickwire) or 10Base-T (twisted-
pair interconnect [TPIC]) connectors. Software controls which one of these
interfaces is enabled.
The real-time clock provides time-of-year (TOY) reference and 50 bytes of
nonvolatile RAM. A lithium battery supplies power in the event of system
power-off or failure.
The IDC implements both an ISDN interface and telephone-quality audio.
The audio connects to the audio interface module (AIM), which provides
the audio I/O in the Model 500. Audio I/O in the Model 400 is on its I/O
module.
The AIM on the Model 500 supports audio input through either a 1/8-inch
minijack for microphone input, a 4-pin modular jack (MJ) connector for
use of a telephone handset, or an RCA-style phonograph jack used as a
line-in input. Output is provided by the MJ connector as well as by a 1/8-
inch stereophonic jack. The stereophonic jack accepts only a stereophonic
plug. If monophonic headphones are used, a mono-to-stereophonic adapter is
required. On the Model 400, audio input and output is implemented using a
4-pin MJ connector.
Analysis of the complete audio system in a Model 500 shows a frequency
response of 145 Hz to 3,500 Hz, with typical distortion in the 0.8 percent
to 1.9 percent range for the microphone and 0.4 percent to 1.5 percent for
the telephone handset. The signal-to-noise ratio ranged from 24 decibels
with a minimal signal input to 58 decibels with a high-level signal input.
The TCDS ASIC implements two separate SCSI ports using two NCR 53C94
advanced SCSI controllers (ASCs). The TCDS allows both controllers to have
DMA transfers in progress simultaneously.
TCDS TURBOchannel DMA transactions are aligned 64-byte blocks. Starting DMA
addresses that are not aligned to these boundaries begin with a smaller
DMA transaction. This technique aligns the address so that succeeding
transactions are aligned 64-byte blocks. Large, aligned transactions
increase both TURBOchannel and memory access efficiency.
The TCDS ASIC and the ASCs provide odd parity protection on major data
paths. This protection includes 8-bit parity on the 16-bit bus between the
TCDS and the ASCs, 32-bit parity on TCDS DMA buffer entries, and 32-bit
parity on TURBOchannel transactions, both I/O and DMA.
The graphics subsystem is available separately as the TURBOchannel HX
graphics option card. In addition, high-performance two-dimensional
and three-dimensional graphics accelerators are available through the
TURBOchannel bus for all systems.
The entire system, with the exception of some I/O devices, runs
synchronously. The master system clock is generated by the CPU chip at
a frequency of 25 MHz (22 MHz for the Model 400), resulting in system
clock cycles of 40-ns duration. This master system clock is duplicated
and distributed with differential pseudo-emitter coupled logic (PECL) to
maintain minimum skew and to improve noise margin. The PECL clocks are
converted to transistor-transistor logic (TTL) in the last stage of the
clock fan-out tree.
Two stages of system clock fan-out are used as shown in Figure 9. Two
MC100E111 ECL clock buffer chips (PECL input and output) provide 18
low-skew differential copies of the clock. Seventeen MC100H641 ECL-to-
TTL converters (PECL input, TTL output) are distributed throughout the
system and I/O boards to provide more than 100 clock lines. All clock
lines are length matched to reduce skew, and PECL wires are separated
from TTL. Worst-case SPICE simulation indicates a skew between typical
components such as PALs to be 1.5 ns. Actual skews measured in the lab are
approximately 0.5 ns.
To give designers maximum flexibility, four phases of the system clock
are generated, one every 10 ns. Delay lines are used to generate an offset
of 10 ns. By swapping the high and low differential inputs to selected
MC100H641 converters, the 20- and 30-ns delayed clocks are generated.
The master system clock is delayed using delay lines so that the eventual
system clock is synchronous with the CPU chip.
The nine ASICs in a DEC 3000 AXP workstation use six unique 1.0-micrometer
complementary metal-oxide semiconductor (CMOS) designs. (See Table 2.)
Plastic quad flat packs (PQFP) are used as the packaging technology to
limit device cost. Because the ASICs are I/O limited and the PQFPs do
not have ground planes, the effects of simultaneous switching outputs
(SSOs) were a concern. The potential effects of SSOs in CMOS output buffers
include corrupted data and undesirable oscillations. Simulation and bench
characterization were used to quantify the SSO effects, and in some cases
SSOs were reduced by staggering output driver timing.
Although ASICs were chosen for the data path, PALs were used for control
logic due to their greater flexibility and faster turnaround time. A
total of 63 20XX (5 ns) and 22V10 (10 ns) PALs with 57 different codes
was used. Exhaustive system-level simulation and bench characterizations
were performed to understand device behavior in the many different loading
scenarios.
The CPU board technology proved moderately difficult for system-level
assembly due to the large distance between the fine-pitch (25 mil)
components. There are 19 fine-pitch components on the 14- by 16-inch
CPU board, with a maximum distance of 14 inches between any two devices.
With this large distance, an aggressive, true positional diameter (TPD)
tolerance requirement of 6 mils was implemented. TPD is defined as the
total diameter of permissable movement from a theoretical exact location
around the true position of the pads. This TPD requirement ensures proper
positional accuracy between the solder paste stencil apertures and the
surface-mount features. In addition, solder mask between pads on the fin-
pitch components is used to reduce manufacturing defects.
To reduce power and cost, the slower DEC 3000 AXP Model 400 design
substitutes CMOS technology for the BiCMOS cache SRAMs and for many of
the bipolar PALs.
The power supply also provides power for three external fans. Temperature-
sensing fan speed control is provided to reduce system noise. The power
supply senses tachometer outputs from the fans, and when a fan fails, it
shuts down and illuminates an indicator.
The DEC 3000 AXP workstation takes full advantage of the serial ROM port on
the DECchip 21064 CPU. This port allows code to be directly loaded into the
instruction cache. During prototype development, designers loaded special
debug programs into the CPU through this port. However, the real innovation
is in also wiring this port to the output of a 64K by 8 EPROM on the module
to provide 8 programs that are individually selectable by moving a jumper
on the module. On system reset, serial program data from the selected EPROM
output is loaded into the instruction cache. These programs include power-
up code for loading the real console, a miniconsole, and five diagnostic
programs for testing memory and the graphics subsystem. Other tests are
available by replacing the EPROM. These programs are of great value in the
manufacturing debug environment.
Two flash EPROMs contain the console code for the system. On power-up, code
in the serial ROM loads the console code into memory and begins executing
it. Users can easily update the console ROMs (for example, to provide PAL
code enhancements) through a special utility booted off a CD-ROM connected
to the system. Field service can update the console code in the system
remotely through the Ethernet.
Another goal of the project was to offer performance that is competitive
with RISC workstations available from other vendors. The benchmark
performance of any system derives from the interdependent performance
of the hardware, the operating system, and the compilers that generate
the application code. The benchmark performance should improve as each
element matures. Table 4 shows the performance of the DEC 3000 AXP systems
on a selected set of benchmarks as of the announcement dates of these
products. Table 5 compares the performance of the DEC 3000 AXP Model 500
to the published performance of several currently available competitive
systems.[4]
Copyright © 1992 Digital Equipment Corporation.
Forwarding and copying of this
article is permitted for personal and educational purposes without fee
provided that Digital Equipment Corporation's copyright is retained with the
article and that the content is not modified. This article is not to be
distributed for commercial advantage. Abstracting with credit of Digital
Equipment Corporation's authorship is permitted. All rights reserved.
A family of high-performance 64-bit RISC workstations and servers based
on the new Digital Alpha AXP architecture is described. The hardware
implementation uses the powerful new DECchip 21064 CPU and employs a
sophisticated new system interconnect structure to achieve the necessary
high bandwidth and low-latency cache, memory, and I/O buses. The memory
subsystem of the high-end DEC 3000 AXP Model 500 provides a 512KB secondary
cache and up to 1GB of memory. The I/O subsystem of the Model 500 has
integral two-dimensional graphics, SCSI, ISDN, and six TURBOchannel
expansion slots.
CPU Module
The DEC 3000 AXP systems are composed of two primary modules, the CPU
module and the I/O module. The CPU module contains the processor, secondary
cache, control logic, TURBOchannel interface and, in the Model 500, the
two-dimensional graphics subsystem. It has connectors for the I/O module,
four memory mother boards, a lights and switches module (LSM), three
TURBOchannel options, and the power supply. Figure 3 shows the layout of
the module.
CPU
B-cache Subsystem
The system employs a second-level cache (B-cache) to help minimize the
performance penalty of misses and write throughs in the two relatively
small 8KB primary caches of the DECchip 21064 processor. The B-cache is a
512KB, direct-mapped, write-back cache. A direct-mapped cache eliminates
the logic needed to choose among the multiple sets of a set-associative
cache, resulting in a faster cache cycle time. A write-back protocol was
selected because it reduces the amount of write traffic from the B-cache to
main memory, leaving more main memory bandwidth available for other memory
transactions.
Memory System and System Crossbar
The DEC 3000 AXP Model 400 and Model 500 architecture supplants the
traditional system bus with a system crossbar constructed from ASICs.
Tightly coupled to the crossbar is the system memory. Three types of ASICs-
SLICE, ADDR, and TC-form the crossbar. SLICE and ADDR are discussed next
and TC is discussed in the I/O Subsystem Interface section.
SLICE ASICs
The four SLICE ASICs are used strictly for data path; together they form
a 32-byte bus to main memory, a 16-byte bus to the CPU and cache, and a
4-byte bus to the TC ASIC. It is helpful to think of the SLICE ASICs as a
train station for data with the data buses as train tracks. Data can come
and go on any track, different tracks have different speeds and widths,
and data can find temporary storage in the ASICs. The SLICE ASICs provide
the systems with a location to buffer DMA, I/O read, I/O write, and victim
data while the data waits to travel the next leg of its journey. The use of
the SLICE ASICs also eliminates one to two levels of buffering between the
dynamic random-access memories (DRAMs) and the CPU, thus decreasing latency
and improving bandwidth.
ADDR ASIC
The ADDR ASIC is a crossbar for addresses. ADDR sends addresses from the
CPU to memory (CPU reads and writes), from the CPU to I/O (I/O reads
and writes), and from the I/O to CPU and memory (DMA reads and writes).
ADDR selects between CPU read, victim write, and DMA addresses to send to
memory. A counter that increments DMA addresses on long TURBOchannel DMAs
also resides in ADDR.
Memory Mother Board and SIMMs
The memory system is composed of memory mother boards (MMBs) that rise
from the system card, and SIMMs. This arrangement is a good solution to the
problem of limited space on the system module. It allows for a wide data
bus and for good signal integrity for short propagation times on the memory
data bus.
Memory Transactions
When data is stored in the B-cache by the CPU, it is not immediately sent
to memory. Data is written to main memory only when a dirty block in the
cache is replaced. Data destined for the cache is read from main memory
only on cache misses. Reads to main memory, whether from the CPU or from
DMA, always return 32 bytes. On CPU reads of main memory, data is returned
to the cache and CPU in two halves by the SLICE ASICs. Likewise when the
B-cache control writes victim data to main memory, two reads are made of
the cache, but only one write is made to main memory.
I/O Subsystem Interface/TURBOchannel ASIC
The I/O system is based on the TURBOchannel, a 32-bit high-performance,
bidirectional, multiplexed address and data bus developed by Digital for
workstations.[3] The DEC 3000 AXP supports up to six plug-in options,
as well as the integral smart frame buffer (SFB) graphics ASIC, the I/O
controller (IOCTL) ASIC, and the TURBOchannel dual SCSI (TCDS) ASIC. The
TURBOchannel bus is synchronous and requires only five control signals in
each direction between the system and the option cards.
I/O Subsystem
Most of the I/O subsystem is implemented on its own module. This I/O
module, shown in Figure 8, contains the connectors for attachment unit
interface (AUI) Ethernet, 10Base-T Ethernet, Integrated Services Digital
Network (ISDN), alternate console/serial printer, mouse/keyboard,
communications, internal and external SCSI, three TURBOchannel options,
and audio module port. The various I/O controllers interface to the
TURBOchannel through one of three ASICs. These ASICs are the smart frame
buffer (SFB) on the CPU module and the TURBOchannel dual SCSI (TCDS) ASIC
and the I/O controller (IOCTL) ASIC on the I/O module.
I/O Module-IOCTL ASIC
A key I/O subsystem design decision was to reduce time-to-market by
eliminating unnecessary new hardware and software development. To support
most of the I/O functionality, the designers chose the IOCTL ASIC developed
for the DECstation 5000 Model 240.
I/O Module-TCDS ASIC
Although the IOCTL ASIC contains an interface to a SCSI controller, the
DEC 3000 AXP systems implement their SCSI interface using the TCDS ASIC.
This design has several advantages. First, the TCDS ASIC supports two
SCSI ports rather than the one supported by the IOCTL ASIC, permitting
separate internal and external SCSI chains. Second, this design eliminates
contention between the Ethernet controller and the SCSI controller for
the IOCTL bus. Third, the TCDS ASIC supports much longer TURBOchannel DMA
bursts (64-byte bursts rather than 16-byte bursts). Finally, the resulting
ASIC design is used to implement a dual SCSI TURBOchannel option module.
Graphics
The graphics subsystem on the Model 500 system card provides integral
8-plane graphics with hardware enhancements for improved frame buffer
performance. These enhancements increase the performance of stipple, line
drawing, and copy operations. The graphics system consists of an SFB ASIC,
2MB video RAM, and the Brooktree Bt459 RAMDAC chip for sourcing the 8-
plane RGB data. The user can select either a 66-Hz or a 72-Hz monitor
refresh rate through a switch on the back of the workstation. The graphics
subsystem can draw 615K two-dimensional vectors per second and can perform
copy operations at 31.8MB/s.
Clock System
The input clock circuitry to the DECchip 21064 CPU contains a differential
300-MHz oscillator (266 MHz for the Model 400), which drives an alternating
current (AC) decoupling circuit and the CPU chip. The CPU chip divides down
the input clock frequency by a factor of two and operates internally at 150
MHz. The DEC 3000 AXP Model 500 is capable of supporting a 200-MHz CPU with
a 400-MHz oscillator.
Technology
The goal in choosing semiconductor devices was to select mature silicon
technologies and then push those technologies to the limit. Module- and
chip-level signal integrity was verified by correlating silicon bench
characterization data to device simulation modules. CAD tools were used
to perform worst-case module timing and signal integrity simulation. This
methodology minimized device costs, reduced risks, and shortened time-to-
market.
Power and Packaging
The Model 500 has a 480-watt output, off-line, switching regulated power
supply, which includes a capacitor-input, automatic voltage-selecting
circuit to permit worldwide operation without a voltage-select jumper for
120 or 240 volt (V) input. The power supply provides five outputs to the
load: +3.3 V, +5.1 V-CPU, +5.1 V-turbo, +12.1 V, and -12.1 V.
Manufacturability/Testability
The designers provided several debugging features, including test points
on the module, tristate outputs on ASICs and PALs, an on-board diagnostic
ROM, and programmable console ROM. Since the module is composed almost
exclusively of surface-mount devices, the designers specified as many vias
as possible for use as test points. Consequently, all wires on the board
have test points, which allows for 100 percent short-circuit coverage and
94 percent open-circuit coverage.
Conclusions
The primary goal of this project was to design a balanced system that
exhibited low memory latency, high memory bandwidth, and minimal CPU-I/O
memory contention in a cost-effective manner. Table 3 gives the measured
peformance numbers for these characteristics. Except where noted, all
numbers are for sustained performance. Of particular note are the numbers
showing that the CPU receives significant memory bandwidth even in the
presence of heavy block I/O and DMA traffic.
Acknowledgments
The DEC 3000 AXP Model 500 design was a team effort-more people were
involved than can be acknowledged in this space. Recognition is due to
those who contributed to the design of original hardware: Dave Archer, Mark
Baxter, John DeRosa, Chris Gianos, Leon Hesch, Dave Laurello, Bob McNamara,
Dick Miller, Rick Rudman, Dave Senerchia, Petr Spacek, Bob Stewart, Ned
Utzig, Debbie Vogt, and John Zurawski. The tight schedule could not
have been met without the special efforts of the Power and Packaging,
Console, Qualification, Proto Management, and Technology and Operating
Systems Groups. The design team for the DEC 3000 AXP Model 400 project is
also recognized: John Day, Jamie Pierce, Dennis Rainville, and Ken Ward.
The thorough device evaluations by Rob Zahora contributed significantly
to the success of the projects. We would also like to acknowledge the
contributions by FXO personnel. The Electronic Storage Development Group
was responsible for the design of the DEC 3000 AXP Model 500 memory module.
Significant efforts by the Maynard TME, Albuquerque, and Ayr Manufacturing
Plants should be recognized for delivering quality hardware during the
development and production phases; a special thanks to Jim Ersfeld for his
significant efforts in this regard.
